Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
Docker Masterclass
  • Masterclass Type: Core
  • Maximum Expected Time To Complete: 2 hours
Table of Contents
Docker is a set of services that use OS level virtualization to run self-contained instances of software. These instances are known as containers, and include everything that the software running within them needs to function apart from the Linux kernel.
This Masterclass is an aside to the rest of the balena Masterclasses, in that it focuses specifically on Docker, from the basics to some 'deep dives' into how containers (and other components) function and are constructed.
It is anticipated that after reading the basic sections of this Masterclass, the reading of the Services Masterclass will allow anybody to develop balena apps and services.
Hardware and Software Requirements
It is assumed that the reader has access to the following:
  • A locally cloned copy of this repository, Docker Masterclass. Either:
    • git clone https://github.com/balena-io/docker-masterclass.git
    • Download ZIP file (from 'Clone or download'->'Download ZIP') and then unzip it to a suitable directory
  • A suitable text editor for developing code on your development platform (eg. Visual Code)
  • A suitable shell environment for command execution (such as bash)
Exercises
All of the following exercises assume that you are running the Docker CLI from a suitable Unix based shell. The exercises include commands which can be run in such a shell, and are represented by a line prefixed with $. Information returned from execution of a command may be appended under the line to show what might be returned. For example:
1. Introduction to Docker
Docker allows the execution of software in self-enclosed packages called 'containers'. Containers are essentially small execution environments, and can range from being tiny environments where only a few binaries are included, to fully blown Linux distributions such as Debian or Ubuntu where many packages can be included for the container environment to use (eg. via the use of apt-get in the case of Debian or Ubuntu).
As such, Docker features some very useful benefits:
  • The ability to run applications/binaries in a sandboxed execution environment where malicious code will not have access to the host OS.
  • Easy and rapid deployment to a machine that Docker is installed on, with the assurance that the containers will run in the same way as on any other system with Docker installed.
  • Rapid development due to the quick building and recreation of containers, as opposed to having to reinstall an OS and dependencies on a bare-metal or Viritualised system.
Containerization is an alternative form of providing host OS separation to that of an execution environment, where other forms include Virtualization, where machine resources (such as CPU cores, memory and disk space) are partitioned off from the host OS and used to run a guest OS instead. Unlike Virtualization, Containerization uses host OS resources as it needs them at runtime. As such, there is no need to pre-allocate resources.
Docker runs as a service, how this occurs depends on the host OS:
  • Linux - Runs as an OS daemon service (such as a systemd unit file), which is then sent commands via the docker and docker-compose clients.
  • macOS - A Xen Hypervisor Virtual Machine runs the Docker service, and a UI and CLI client connects to it.
  • Windows - A Virtual Machine (called MobyVM) is run, with the UI and CLI client connecting to it, or via WSL.
At this point, it's worth introducing some terminology, so that we can easily refer to concepts in the future. It's worth noting that some of the concepts described in the terminology will be described later in the exercises.
  • Layer - A layer is part of a Docker Image or Container. It represents a file system layout, comprised of both directories and files. Layers are created during the building of a Docker image, or whilst a container is currently running.
  • Image - A Docker image is a self-contained object representing a file system, comprised of Docker layers. The number of layers in an image vary from a minimum of 1. Images are created from Dockerfile 'recipes', which contain a number of directives that allow the image to be created by carrying out operations such as copying files into the image, executing commands to configure the image (such as apt-get from a Debian base image, or running bash scripts to generate configuration files) and determining which binary will be executed when the image is run as a container.
  • Container - A Docker container is a running instance of an image. When an image is selected to be run, a new container is created that uses the layers from the Docker image as the base filesystem (the image acts as a 'template' for the container and the container never alters the image), and then runs any command that has been given. Should the container create any new files, or update any files that existed in the Docker image that is not located in a bound volume, a new layer that is owned specifically by that instance of the container is created. Container layers persist for the duration of the container's life, but are removed on container removal.
  • Volume - A volume is persistent storage that exists as a directory structure on the host OS, which can be bound to a container on startup. This can work in several different ways, such as binding a specific directory or file from the host OS into a specific location in the container (for example binding /etc/hosts from the host OS to /etc/hosts in the container) or binding a named volume (a Docker managed directory on the host OS) into a specific location in the container (for example using a volume called shared-volume into /usr/share in the container).
  • Network - A Docker network is functionality to connect running containers to each other and/or other network interfaces running on the host OS. These can vary from simply using the host OS's networking interfaces, to user-defined networking bridges which are only used by particular containers. All containers that require incoming/outgoing network traffic require a Docker network of some description.
  • Repository - A Docker repository is storage for Docker images. When a Docker image is built, it is stored in the local Docker repository. However, usually you'll want to store the image in a location where other users can retrieve it. Docker repositories can be private (so that only users with login credentials can retrieve images from them), public (so that any user may retrieve an image from them) or a mixture of both. The Docker CLI includes commands that allow you to pull/push images from/to repositories.
2. Installing Docker
How you install Docker onto your local host OS is dependent on the OS itself and the distribution that you're running. Docker has instructions available that allow the user to easily carry this out here.
An important note here. When installing Docker under Linux, the Docker daemon (usually, unless changed) runs as root (under Windows and macOS, this is not an issue). As such, you'll need to follow the instructions to add any user that also wants to run the docker command to the docker group. If you don't do this, only the root user will be able to use Docker under Linux. For convenience, the command to do this is:
Where <your-user> is the username for the user to run as non-root. However ensure that this is the latest command under the Docker installation instructions before doing so. You'll need to log out of the shell and then back in for the changes to take effect.
Under macOS and Windows this is slightly different, and the installing user will be asked to enter their credentials so that the Docker Hypervisor/VM has permission to run in the background.
Once you've installed Docker, you should be able to open a new shell terminal and verify that Docker is running correctly by running:
3. The docker Command Line Interface
Whilst the Docker daemon runs continuously on your host OS, it can be controlled via the docker CLI command. This contains all the functionality to build images, run containers, create volumes and networks, push and pull images to remote repositories, etc.
We'll be using docker for almost all of the exercises, so it's worth having a quick look at all the available commands:
4. Introduction to Dockerfiles
The basis of any Docker image is the Dockerfile. This is a list of instructions that form a recipe for an image. When an image is built, Docker steps through the instructions in the Dockerfile and carries out the directive at each step. Directives are keywords which (usually) form the start of a new line in the Dockerfile.
As mentioned, Dockerfiles are laid out as a series of directives, which are executed in series. Here's a very basic example:
This Dockerfile:
  1. Uses the latest Debian Buster base image (containing all the files in the Buster release) as the base for the image's file system.
  2. Copies a local binary (helloworld) from the same directory that the Dockerfile is in into the image's /usr/src directory.
  3. Sets the command that should be run when the image is run as a conatiner (in this case, it will run the /usr/src/helloworld) binary.
We'll go through some of the most common Dockerfile directives, and what they do, followed by an exercise to build a very simple Dockerfile, but we'll introduce some more keywords later in the Masterclass when we've pinned down the basics.
4.1 FROM Directive
The FROM directive usually starts a Dockerfile. It informs Docker of the image that should be inherited from as a basis from with which to run the rest of the directives in the Dockerfile.
Because images are formed of a set of file system layers, an image can actually inherit another image as its base, which therefore gives it immediate access to the filesystem layout that exists in the base image.
Here's a small example. Consider an image, let's call it 'simple-base', which has the following directories and files in its layers:
We can use the FROM directive at the start of a Dockerfile to inherit from this base image:
You'll note that comments can be used in Dockerfiles, by simply using # at the start of the line, very much like Linux/Unix shell operations.
Further directives in the file can carry out operations on the inherited filesystem, as well as creating new layers which include new or modified directories and files. Every time the filesystem is modified via the Dockerfile, a new layer is created. This usually occurs after each directive.
As well as inheriting from base images, it's also possible to start a completely new Docker image which does not include any layers. This can be achieved by using the special image name scratch. This tells Docker it shouldn't try to inherit from any other image, but start a brand new set of layers. In fact, this is how a large number of 'standard' base images start, such as the Docker versions of Linux distributions, by starting from scratch and copying in all of the files that build up that distribution of Linux.
4.2 COPY Directive
Now we know how to use a base image to start with a filesystem in our own image, but how do we get new files into it?
This is where the COPY directive comes in. This allows the copying of files from the host's local filesystem into the Docker image being built. It's fairly similar to the standard copying commands under most OS variants in that it takes the location of a source file or directory on the host and a destination where the contents of the source should be copied inside the image. COPY preserves all flags on the file when copied. For example, if you copy a shell script that has the execution flag set this will be preserved when copied into the image.
NOTE: The directory location of the Dockerfile being used to build the image is known as the build context. Any files in the build context, or any of its sub-directory hierarchy, is also part of the build context. This can be changed by other commands, but this is the default and we'll be using it for the moment.
The following will recursively copy the contents of the directory-3 directory in the current build context into the image at the location /directory-3:
Note that you need to add the trailing / to the destination directory. If the destination directory doesn't already exist, it'll be dynamically created (which means you can specify a nested destination directory without having to run mkdir in the image).
Wildcards also work, so that the following:
Will recursively copy everything (including the Dockerfile) in the current build context to the /all-the-files/ directory in the built image.
It should be noted that the source of files are always relative to the build context. Therefore files must be available to that context (you can't, for example, reference files that are in the directory above where the Dockerfile is, because it's not within the same context).
COPY has a few switches that include abilities to set ownership and on files as they're copied. Refer to the Dockerfile documentation for more details.
If you want to use files that are outside of the build context there are a few tricks we can use, which we'll discuss in an advanced Docker Masterclass.
4.3 RUN Directive
The RUN directive runs commands whilst building a Docker image. This is sometimes confused, when starting out with Docker, with the CMD directive which runs commands when the image is created as a container instance.
RUN is used to carry out processing on your image to make it more useful. Because the RUN command has access to all of the filesystem layers currently available at the point when the directive is executed inside the image, it's used to do things like install useful libraries and packages. For example, suppose we're using a Debian Buster base image, and we want to install the Node.js package, we can use RUN to execute the apt-get binary to do this:
Another example might be running a command on some files in the image, to create new files or modify them. The following will create a new file with some initial text in and then print that file out, before then modifying that file using sed to change the text and printing out the next contents:
As you can see, any binary that's part of the distribution is available, and you can even use files you copy in yourself. Suppose we had a script called list-files.sh in the current build context that was simply:
We could copy this into the Docker image during the build and then run it:
This would copy the script into the image at location /list-files.sh, and then run that script to get a list of all the entries in the root directory to a file and then outputing the contents to the build.
4.4 CMD Directive
The CMD directive is usually the last directive in a Dockerfile. This informs Docker what should be run when a container instance is created from an image.
This tends to be a call to a single binary or script. Once the call has finished, the container will exit. Because most Docker images are designed around services or daemons (for example a web server or similar), it's unusual for a CMD to not start up a daemon or script that restarts should that service exit. But this doesn't mean it has to be like that.
Taking the example from the RUN directive explanation, the following will set the command to run when the container is instantiated to list the entries in the root of the file system:
After the command has run, it will return and the container running it will exit. Parameters can be passed to it by simply adding a space between the executable and the parameters:
We've actually used what is known as the 'shell' form of the CMD directive here. In this case, before the /list-files.sh script is run, a shell is created inside the container to run the command (it is essentially wrapped inside a /bin/sh -c <command>).
There's also an alternative form of the command, called the 'exec' form, which uses a JSON array to call an executable and pass parameters to it without a shell. We'd call our script in the same way in this form as such:
Here, the command being executed is the shell itself (/bin/sh) and the parameters passed signify to run a command in it (-c) and the command to run (/list-files.sh). Of course, if the command to execute was a binary, we could just use CMD ["/path/to/binary", "param1", "param2"] instead, and in fact because list-files.sh includes the environment to use in its header (#!/bin/bash) we could run the script without invoking bash first.
At this point, most users would say "I think I'll use the shell form, it's much quicker to write". But beware! Whilst the second form of CMD does indeed require you to use a JSON structure, it also ensures that signals passed to the container are propagated to it. That means that when the container is stopped using docker stop, the SIGTERM signal is correctly passed to the script or executable that allows it to clean up correctly. Using the 'shell' form will cause the process to be effectively be SIGKILLed.
As such, you should always use the 'exec' form unless there are very good reasons for not doing so.
As the CMD directive informs Docker of what to run when a container is started, there should only ever be one CMD directive in a Dockerfile. If more than one exist, only the last CMD directive seen will be run. Sometimes this can be useful, if you want to use a base image which usually runs as a service, but wish to override the CMD directive from that base image (perhaps you want to run with different parameters, or use the base image because of the filesystem layers it includes).
The CMD directive can also be used in conjunction with the ENTRYPOINT directive, which we'll describe in a more advanced Docker Masterclass.
5. Building a Docker Image
Now that we know some of the basic Dockerfile directives, it's worth learning how to put some of these together to build a simple Docker image.
For convenience, export a variable to point to the root of this masterclass repository, as we'll use this for the rest of the exercises, e.g.:
Now change directory to the simple-docker-app directory in the root of this masterclass repository, e.g.:
Note that for the rest of these exercises, we're assuming that you're using an x64 based machine. Should you be using an alternative architecture, such as Arm, you'll need to change the architecture of the base image that you're using in the Dockerfiles.
We're going to use balenalib based images in the remainder of the exercises in this Masterclass, as they include useful images which are 'ready to go' with various languages, libraries, etc.
Load a code editor of your choice, and edit the Dockerfile file in the simple-docker-app directory. Add the following:
Ensure you have a newline at the end of the Dockerfile. Let's quickly run through exactly what this Dockerfile does:
FROM balenalib/intel-nuc-debian-node:latest This declares that the Docker image built should inherit from the balenalib/intel-nuc-debian-node:latest image, which in this case is the latest Debian Node.js image built and tagged by balena. This image includes all standard Debian packages, binaries and libraries, as well as a copy of the Node.js language and runtime, and npm. This allows us to easily run the Node.js source code located in index.js.
COPY * /usr/src/app/ This copies all of the files in the simple-docker-app directory (the current Docker build context) into the image being built in the /usr/src/app directory which is dynamically created first.
After changing directory into the /usr/src/app directory, the npm install command is run, which uses the package.json file previously copied to this location to install all of the required npm packages specified in it. This creates a /usr/src/app/node_modules directory with all the dependencies in.
As previously described, the CMD directive informs Docker what to run when the Docker image is instantiated as a container. In this case, because the directive is using the exec format, full paths to the command to run need to be given (/usr/local/bin/node for the Node.js executable), as well as the source file (/usr/src/app/index.js).
Once you've edited the Dockerfile, we can build a Docker image from it using the following docker CLI command:
The docker build command itself instructs the Docker daemon to build a new image, the --tag (shortened form -t) switch informs it how to name the image (naming is in the form of repository:tag, where the tag is optional), and the . is the path to the build context, in this case the directory we're running the command inside.
As you can see, quite a lot happens here. You'll see that there are several steps which get output (eg. Step 1/4 : FROM balenalib/intel-nuc-debian-node:latest). As you may have noticed, each of these steps corresponds to a Dockerfile directive. Therefore you can quickly see which directive is being run by the step that's being carried out. In this case, the Docker daemon pulls the base image required (and during this you can see each individual image layer that makes up the base image being pulled), before copying the files into the image, carrying out the npm install and then setting the command to run on container instantiation.
Another really important point to note here is that when a Dockerfile is processed, new layers for that image are created by particular directives. Generally, new layers are created by each new Dockerfile directive (this is not always true, but at this point, thinking about it in this way is useful). As such, consolidating command into statements such as RUN can be useful, as it limits the number of layers produced in an image. We'll go more into these techniques later in the Masterclass.
We can now list the images by running:
Note that each image has a repository name, tag and image ID. Most Docker commands working with images can take the name of the container or the ID. If using the container name, note that a Docker image repository name can be used with or without a tag, however if there is more than one tag for an image's Docker repository name, the latest tag will be assumed if not given.
More information about repository naming and tags will be discussed in a later exercise.
As you can see, we have a total of two images. The first is expected, because this is the image we just built (simple-docker-app), but the base image that our Docker image has inherited from is also present (balenalib/intel-nuc-debian-node). This is because Docker stores each image, including base images that others inherit, separately inside the system. When a container is created from an image, all the layers that make up the image are referenced and used by the container. This happens regardless of the number of times an image is used, or how many parents it has. Because layers are referenced and not directly copied, this allows many different containers to run without the resource penalty of copying the same files and directory layouts for each separate instance, thus saving a large amount of space.
5.1 WORKDIR Directive
We now have a built image. However, even though we've a few steps, there's a few things we could so to improve the way it's built. The first is to specify a working directory. The WORKDIR directive tell the Docker daemon that this is our default working directory. Think of it a bit like running cd to change to the directory specified before running any commands.
With that in mind, add a new line to our Dockerfile after the FROM directive:
We'll also now change a few of the other lines to remove specific references to /usr/src/app. Change:
to:
And finally change:
to:
Let's rebuild the image again:
The first thing you'll notice is that the FROM line didn't show the Debian base image being pulled. That's because it's already downloaded and stored it in the local registry.
The next thing you'll notice is that we no longer have to specify the cd to change directory in the RUN command. If we hadn't specified the WORKDIR to use, it would be looking at the root / of the filesystem to run npm install and would fail as the package.json would not exist there.
Finally, we no longer have to specify the full path of the index.js source file, as this exists in the /usr/src/app directory (which is our working directory).
As we've now specified the working directory as /usr/src/app, we could also change the command used to actually run the Node.js app to npm, as it would find the package.json in the same directory and use the start section from it.
Change the final CMD line to:
Finally rebuild the image again so this final line is used, with:
6. Docker Containers
We now have a built Docker image, let's run it! First it's worth noting a little bit about what happens when you run a Docker image and use it to create a new container.
Docker containers run as processes spawned by the Docker daemon. Linux-based, they use the underlying host kernel to do so. Under host OSs such as macOS and Windows, these kernels are supplied by minimal Linux VMs that are closely bound to the underlying host OS so that contexts such as device nodes, networking, etc. are available to the VM kernel and therefore the container running on it.
This explains why OS resources are acquired by containers dynamically (and also released when no longer required), as each running process only consumes what it needs, as it essentially is running on the host OS, albeit in a file system and resource sandbox.
6.1 Running a Container
To run an image as a container, we can use the docker run command. We can either pass the repository and tag name or use the ID. We'll just simply ask docker run to use the simple-docker-app image, without a tag (which will assume it should use the latest tag):
We'll explain the significance of --tty later, but for now it just means that we can stop the container using Ctrl+C when we're done with it. The act of running creates a new container instance based on that image, which is now running under the Docker daemon. Open a new terminal (which from this point on we'll call T2 with the terminal you ran the Docker image in as T1), and enter:
docker ps shows us all the currently running container instances. In this case there's just the one we've started. You can see the command that it's running, as well as the image it's derived from. It also has a container ID (just like an image, each container also has a unique ID) and a name (which because we didn't specifically pick one when running is autogenerated). However, there's also another field you might notice which doesn't have any value associated with it. This is the PORTS field.
If you look at the source code in index.js, you'll see that we've a little endpoint service listening for REST POST requests to the /echo endpoint. You'll also see that the service is running on port 9854. So, let's use curl in T2 to send a POST request:
Well, that's odd! The source for the image shows that the Express server is listening on port 9854, but curl can't get a connection to it. The reason is that whilst the Express server in the container is trying to listen to the port, we haven't actually told the Docker daemon that the container should open a connection to the same port. This actually demonstrates a fundamental principal behind containerization, in that unless specifically instructed, Docker sandboxes all running containers securely away from the host OS.
6.2 Stopping and Restarting a Container
First terminate the container using either Ctrl+C in T1 where it's running, or stop it by running docker stop in T2, passing either its name or ID as a final parameter. In the case of the container we've created here, that would be:
or:
Once stopped, the container no longer shows up as running in docker ps:
But it will show up as a stopped container in the list of all containers if we pass --all (shortened form -a) to docker ps:
The --all (which can also be written -a) switch to docker ps tells it to list all the container instances that are currently available, not just those that are currently running.
We can restart the container easily with docker start, which will allow you to restart any previously created and stopped container instance. Simply pass the name of the container or its ID and Docker will start the container again using the same parameters that it was originally run or created with.
Finally stop the container again before continuing with:
6.3 Creating a Container
Instead of using docker run, we could also use docker create to create a new container from an image. However, this command only creates a container and does not run it. docker create takes many of the same parameters as docker run. To start running a created container, you then need to use docker start on the container name or ID.
6.4 Publishing Container Ports
We'll get into Docker networking later and how traffic is routed, but for now all we need to know is that to ensure that traffic can get in and out of the container so that Express can receive traffic on port 9854, we need to run the container with the --publish command to signal to the Docker daemon that we'd like to 'publish' traffic into it from the host OS.
We're going to re-run the image again, but this time specifying that the right port should be opened up into the container. In T1, run the following:
Note that we specified 9854 twice as the arguments to the --publish switch (this can be shortened to -p). This isn't an error, but it lets us map a specific port inside the container to a port on the host. In this case, we want both port numbers to be the same, but you can change the host port by altering the first argument to be the port on the host you want to use, ie. --publish <hostPort>:<containerPort>. As a final note, --publish also allows ranges of ports from the host to be published (for example mapping all traffic from ports 1234 to 1238 on the host to a single port inside the container would be --publish 1234-1238:1234-1238).
In T2, have a look at the output of docker ps again:
Aha! Now we can see that the PORTS section has a value in it, 0.0.0.0:9854->9854/tcp. This states that port 9854 on IP address 0.0.0.0 on the host OS is mapped to port 9854/tcp inside the container. A couple of things to note are that by default, unless otherwise specified, the Docker daemon will allow traffic coming into the host on any interface through the specified port into the container (hence 0.0.0.0 which states any IP assigned to a valid host network interface). We could have specified a set IP address for the host, for example if we wanted only to let traffic coming through localhost into the container, we could use --publish 127.0.0.1:9854/9854. Additionally you can see that the traffic entering the container from the host on port 9854 is going to port 9854/tcp in the container. TCP is always the default if not otherwise stated. To use UDP instead, simply prefix the published ports list with /udp, eg. --publish 9854/udp:9854/udp would map any traffic from UDP port 9854 on the host to UDP port 9854 in the container.
Finally let's try the curl command again in T2:
Success! We've posted an HTTP request from the host to the Docker container instance, and received a response.
Finally, stop the container currently running either with Ctrl+C in T1, or via docker stop in T2.
6.5 EXPOSE Directive
Whilst we're on the topic of ports, this is a good time to quickly discuss the EXPOSE directive. This can be used in Dockerfiles to state that the container would like to open a particular port when run as a container. Let's try this by adding:
to our Dockerfile (it doesn't matter particularly where for this example, but good practice is near the start of the Dockerfile, after the FROM line). (If you wanted to expose a UDP port, you'd simply specify EXPOSE 9854/udp.)
Now let's rebuild our Docker image in T1:
Now we'll run the new version of the image, but we'll remove the use of --publish and instead use the --publish-all (shortened form -P) switch instead, which will publish all ports specifed in EXPOSE directives in the image to the host:
In T2 run the curl command again:
It looks like curl can't actually connect to the host on port 9854. Let's use T2 again to see what docker ps says:
Interestingly, whilst port 9854 in the container is mapped a port on the host, it's not mapped to port 9854. This is because --publish-all maps ports specified by the EXPOSE directive to ephemeral ports on the host, usually the next free one. This initially doesn't sound particularly useful, but becomes more so in the context of Docker deployments to Cloud hosts where services are usually run.
If we now try curl again in T2 using port 32769 (this will most likely change on your own machine, ensure you use the right mapped port), we'll see that all works as expected:
Any Docker image which has been built with the EXPOSE directive can still be forced to map a specific host port to a specific container port just as before by using the --publish switch to docker run.
Whilst the use of EXPOSE is not mandatory when writing Dockerfiles, its use is encouraged as useful documentation and metadata to those who want to run your Docker images. This stops extra documentation being required to state explicitly which ports your image uses, and also means when you update your image, all a user has to do is see if extra EXPOSE directives have been used and then map the new ports appropriately to the host.
Finally, stop the container running in T1 and then close T2. We'll refer to T1 from this point as 'the terminal' again.
6.6 Container Instances
One thing you may have spotted whilst we were stopping and rerunning our Docker image was that the name and the ID of the container kept changing.
In the terminal, run the following:
However, looking at the list, this seems strange at first. We we just kept running our simple-docker-app, so why are there several instances of it? Well, every time we used docker run simple-docker-app, we were asking the Docker daemon to run a new instance of the image, not to run the same container image that we had before. If we want to re-start an already existing container, we'd simply use docker start.
7. Tags and Caching in Docker Builds
We've previously built an image using docker build, but currently if we make any changes this rebuilds the entire image. In this section, we'll learn how to tag images to give them versioning information, as well as how to use caching to ensure quicker rebuilding of images.
7.1 Tagging Images
You can also see from the container list that only the last container ran using the simple-docker-app image, but why is this? If you remember earlier we discussed that each image name had a repository and tag section. Because we have rebuilt the image several times with changes to the Dockerfile, we've actually changed the resulting image's file system layers and unique hash. This has meant that the latest tag on the simple-docker-app repository has moved each time we've made changes to the image to the newly built version of it. In the above output, both images d00c59983bd8 and f50ceee6da24 were previously called simple-docker-app, as they were the last version of the image to be built. However, as we've built new versions, their name has been changed to that of the image's ID instead, to differentiate them from the other versions.
This again is consistent with how Docker denotes images and containers. If we hadn't made any changes to the image but simply rebuilt it, it would have checked the layers against those that already exist for the image, have seen nothing had changed, and the image would not have been given a new ID or name.
We can easily check this by running the following in the terminal:
The latest image ID for simple-docker-app:latest is 8d1460ff22b2. Let's try rebuilding the image:
The build will finish almost at once; because there were no changes, the image ID build is still 8d1460ff22b2, and the name remains the same:
If we were to make any changes to the Dockerfile or any of the files built into the image, the ID and the name would change again, to denote that the latest version of the image is now different to that previously.
To make this a bit clearer, we'll remove all the current containers and images and start again with a new naming scheme.
In the terminal run:
This will wipe all images and containers from the local repository. Let's quickly break down what that command did:
The docker ps --all --quiet command lists all instances of containers, running or not, and output their IDs and nothing else (the --quiet switch, which can also be shortened to -q). The $() wrapper executes this for the docker rm command, which then removes each of these container IDs from the local repository. You can individually remove a container instance either by using its name or ID, eg. docker rm <IDorName>.
After this, the next command is run:
Similarly to the docker ps command, the --quiet switch to docker images will only output the IDs of the images. This is then exectured for docker rmi which will remove each image by its ID. Again, you can manually remove a Docker image from the local repository with docker rmi <IDorRepositoryName>.
A few things to note here, had we just tried to remove the images without first remove the containers, Docker would have complained that the images were in use by instantiated containers. A quick way round this is to use --force (shortened form -f) when running docker rmi, but bear in mind it will never remove the image from a running container, which must be manually stopped first. Another important note is that whilst the images will be removed doing this, it will not remove containers that have been created from these images.
We're going to now rebuild our image from the Dockerfile, but this time we're explicitly going to give it version tags:
Now run:
Unlike when we built the image before, we have now set a specific tag for the image repository. Also note how the latest tag is not present. Let's try and run the image in the same way we did before, using just the repository name:
Docker can't find the latest tag, because it's not been set, so it is not able to run the image. We could run it by specifying docker run simple-docker-app:v0.0.1, but there's also a couple of ways we can generate the latest tag too. The first would be to rebuild the image with the latest tag as well:
Again, this rebuild was very fast because nothing had actually changed, and all that the Docker daemon actually had to do was add a new tag. Tags show up as separate images. If we list the images again:
You can see that the same image ID is actually related to two different tags. We will now be able to run the image without the specific tag (defaulting to latest) again.
However, if we now change something that alters the image that we build, this will change he situation. In your code editor, change index.js and add a line at the very top that says:
We'll now rebuild the image with:
Finally run:
As you can see, because when we rebuilt we only specified the repository name to -t and not an actual tag, latest was assumed and the latest tag now points to the newer image.
It's always a really good idea to specifically tag the images you're building with a suffix. This stops older built images from losing their repository and tag name, which allows you to easily identify older versions of the image.
To reinforce that point, we'll add one final comment line to index.js, just below the other:
Finally, rebuild the image with a v0.0.2 tag and the latest tag:
And run:
We now have a new version, v0.0.2, which is also the latest version. We also still have our original version, v0.0.1. But note that the version we built without a tag has now been stripped of its repository and latest tag. Because Docker was not given a full repository:tag name for the image, and because we've moved the latest tag on, it's had to remove the name and tag from that image, and it is now only know by it's original ID (4817e03f7def).
7.2 Build Caching
Usually, especially during development of a Docker service, you'll want to change things such as the packages being installed into the image, the source code for the application itself, configuration files, etc.
Whilst our small example Docker image builds quite quickly, if we were to start building very large images we wouldn't want the entire image to be rebuilt from scratch every time we changed a source file that had nothing to do with OS packages being installed.
As we've previously mentioned, when building an image each Dockerfile directive (known as a step) is processed in serial, and these usually result in new layers. However, when building an image, the Docker daemon actually examines the directive and the layers already in the local repository, and determines if it actually needs to create a new layer for that directive or just re-use what already exists.
Let's visualize an example here to make it a bit clearer. Taking the contents of the simple-docker-app Dockerfile you currently have, it'll look something like this:
If we rebuild the app, without making any changes, we'll see that Docker finishes it very quickly:
Note that for each step that gets carried out, Docker reports Using cache. The reason for this is because Docker has noticed that there is already an image that exists based on balenalib/intel-nuc-debian-node:latest, and that for each step in the Dockerfile, there's already a layer that corresponds to this step from a previous build. This only occurs because the steps are in the same order and carry out the same operations. Because of this, it can reuse the layers that already exist. This is called Docker caching, and it's another powerful feature in building Docker images.
However, as soon as something changes either in the Dockerfile directives or any of the files that are used in building the image, this causes Docker to have to build a new layer as it no longer pertains to previously created layers for that step. This is called 'cache busting'.
So now we know a bit more about this, let's change one of the last lines in the Dockerfile so that change the way the output image is built. Just before the final line in the Dockerfile (the CMD line), add the following:
From what we now know, when we now rebuild the Docker image it'll use the cache for all the layers up to the new step we've added with the new RUN directive:
We can see from the build output though, that it has not used the cache for all the steps up to the new directive. In fact, although it used the cache for the FROM, EXPOSE and WORKDIR steps, it created a new layer for the COPY command onwards. But we didn't change anything else apart from the Dockerfile! Well, that actually explains exactly the reason why it created a new layer from that point onwards. Let's look at the COPY command:
This says to copy everything from the current build context into the /usr/src/app directory inside the image. But this includes the Dockerfile itself, which we've changed. Because of this, the layer output would not be the same as the ones from previous builds, as the contents of the Dockerfile are now different. There's a pretty obvious way round this, which is to not copy the Dockerfile as part of the build context. There's a couple of different ways to do this.
The first is via the use of a .dockerignore file. This allows us to specify files and directories that shouldn't be included as part of the context sent via COPY (or ADD which we'll describe later in the Masterclass). In the simple-docker-app directory, execute the following:
This will create a .dockerignore file that says not to copy the Dockerfile and .dockerignore file to the new layer when the COPY command is run. Note that if we hadn't included the .dockerignore file itself, then when a build is next run, cache busting will still occur on the COPY line because the .dockerignore file itself would be copied into the image!
And now let's add yet another line to the Dockerfile just before the CMD:
Run the build again:
So again, this didn't work, why not? Well, this time, the COPY instruction has changed again because now we're not copying the Dockerfile in. Finally, add another new line before the CMD directive:
And now rerun the build:
This time the cache was used for the build right up until the new step we added to the Dockerfile because it's no longer being copied. Finally, remove the RUN lines that we just added.
There's another way to use COPY so that the cache is used efficiently, and that's to only copy files required to build your image. Change your Dockerfile so that the line:
becomes:
If we hadn't have already created a .dockerignore file, this would have much the same effect in that the Dockerfile would not be copied, but only the npm package manifest and the source code.
Only copying what's required for a Docker image build is a very good habit to get into, and is usually used in conjunction with .dockerignore files to ensure that the cache is always used as much as possible.
The second way to ensure that the cache is used as much as possible is to consider how files and directives may affect those that come after it in the Dockerfile. By now, your Dockerfile should look something like this:
Ensure that's up-to-date by building it with docker build -t simple-docker-app:latest ..
Now remove the two lines in the index.js source file we added earlier, ie.:
As expected, because we've removed the two lines from the source file, everything from the COPY directive onwards has forced a cache bust and new layers. However, there's actually something we can do here to ensure that fewer new layers are required and that the majority of the build is used from the cache. Note that we need the npm manifest (package.json) file to carry out the npm installation of required modules. But this isn't actually something that altering the source file changes. As we're not changing the manifest, we could actually split up the COPY commands so that if only the source file changes, the previous npm installation layer is used from cache. Change the following lines in the Dockerfile:
to:
And rebuild the image again:
Now change the index.js source file again and re-add those two comment lines:
at the start of the file. Finally let's rebuild again:
The build was far quicker as npm didn't have to reinstall the used modules again, and the filesystem layer already built was reused:
Considering how your Dockerfile is constructed, and how the cache may be utilized, is an extremely important part of using Docker. Whilst the example we've used is very simplistic, for builds where a Dockerfile is many lines long this can be critical in cutting down build time from hours to minutes.
8. Running Containers in Detached, Command and Interactive Modes
So far we've docker run to create a new container, which outputs all stdout to the console.
However, there are multiple ways in which a container can be instantiated.
8.1 Detached Mode
Detached mode is pretty much what it sounds like. A container can be run, and then detached from the current terminal to be run in the background by the Docker daemon. In this mode, once the container is started it is detached from the terminal, with no output being logged to it.
This can be achieved by passing the --detach (shortened form -d) to the docker run command. Let's give this a go now:
Notice how this time, we haven't passed --tty. That's because we're inherently detaching the terminal from the Docker container, and the --detach would essentially be in conflict. The output from this command is the ID of the now running docker container:
We can still use the container in detached mode, of course:
The container will now run until explicitly stopped. However, we may want to see what it's doing. We can easily do this by using the docker attach command specifying the name or ID of the container:
Start a new terminal and in it run the curl command to our container again:
Note that in the terminal where we attached to the container, we see:
Ctrl+C in the terminal where we attached to the container will stop that container, because we reattached to it after starting it in detached mode. However, it's very important to note that if you run a container in detached mode (or use docker start with its default parameters on a stopped container), you need to use docker stop explicitly to stop that container if you do not reattach a terminal to it.
Finally (if you haven't already), stop the running container.
8.2 Command Mode
A container can also be run by overriding the default command that it uses (the CMD directive from the Dockerfile). Here, the command that you want to run instead is passed as the last parameters to the docker run command. Let's try this now by running the following:
Note that once the command exits, the container itself stops running. This is because the command that we've used to override the default container command is not a long running command, which brings us to another important point. Docker containers only run for as long as the command they've been asked to execute runs. As soon as that command exits, the container stops running.
We also don't use the --tty switch, because we're running a command we expect to exit either successfully or with an error code, rather than a long-running process that might need to be manually terminated.
8.3 Interactive Mode
8.3.1 Via docker run
Docker containers can also run in interactive mode. The stdin stream is passed to the container from the host, which allows input directly into the container. The --interactive (shortened form -i) switch passed to docker run allows this, and it's usually used in conjunction with --tty (shortened form -t) to allocate a psuedo terminal to the container. This allows us to perform many operations as well as send signals (which is why Ctrl+C stops the container running), but is also a very good way of quickly running interactive commands in the container. Because we're using Node.js inside our container to run the listening HTTP server, we can use interactive mode to get a psuedo terminal into the Node.js interpreter. Run the following:
As you can see, we've now been able to gain a TTY into the Node.js process. Feel free to run some JavaScript statements in it, and when you've finished hit Ctrl+C twice to exit the interpreter. This will finish the interactive session within the container, and the container (because we overrode the default command by running /usr/local/bin/node) will stop.
Most non-lightweight Docker images are built based on top of a Linux distribution of one kind or another. Our particular image was built using Debian Buster as its base. Because of this, we can very easily use the inbuilt bash shell to get a TTY connection into the container and run it as if we were just using another installation of Debian:
Again, because we overrode the default command, the HTTP server isn't listening, but because we've started an interactive container session using the shell, we can actually easily run it:
If you now sent a curl command to the HTTP server, it would respond appropriately.
Finally, exit and stop the container by using Ctrl+C to stop the HTTP server and then exit to leave the interactive bash shell in the container.
8.3.2 Via docker exec
Whilst docker run in interactive mode is very useful for examining the container and its contents, because we're overriding the default command from the Dockerfile, it means we have to manually run the command which would have otherwise run on startup if we want to see the container running 'as normal'.
There is another command though that allows us to run a command in an already running container. This is docker exec, and it behaves in the same way as sending a command parameter to docker run, except that it does this on already running containers.
To demonstrate, run a container in detached mode to start the HTTP server:
As we're running in detached mode, we can now send a curl command to prove the HTTP server is listening:
As we have the ID of the running container, we can now execute a command using docker exec (obviously change the container ID appropriately):
We now have a bash shell into the container and as we can see, the npm start from the CMD in the Dockerfile is running correctly as PID 1.
Finally stop the container:
9. Bind Mounts and Volumes
As we've discussed previously, when an image is run and becomes a container instance it uses the image's layers as the base file system for that container. Whenever a container makes changes to the file system, a new layer is created for that specific container instance with the relevant changes.
Because of this, any changes that the container makes to the file system is only persistent for the life of that particular instance. Other instances will use different layers, and none of these changes will occur in the image.
Deletion or recreation of the container will see these container instance layers discarded. Whilst this is useful for transient files and directories, there are times when files need to persist.
For example, suppose you've written an application where one Docker image deals with storing and retrieving data from a database. A container instanced from the image could store all of the data in a new layer, but should you want to change the underlying code, create a new version of the image and then use it, you can't update to this new version without either throwing all of the stored data away or carrying out a very painful migration of the data from the old container instance to the new.
This is where bind mounts and volumes become useful. When a container is created or run, you can specify a bind mount or a volume to attach to that container. This allows the container to then use the bind mount or the volume as another filesystem path within the container, which allows for persistent storage outside of the container.
9.1 Bind Mounts
Bind mounts are directories or files that pre-exist on the Docker host machine that, when specified on running, or creating a new container, get bound into the container at a given destination path within that container.
This essentially allows the host machine's filesystem structure to be shared with a container. Any changes made to the bound directory/file inside the container will therefore change in the host, and vice versa.
To bind a directory or filepath to a container, simply use the --mount switch passed to docker run or docker create. --mount takes several options (separated by commas), which allows the source filepath, destination filepath, type of mount, etc. to be specified.
Let's carry out a quick example of this. We'll use the balenalib/intel-nuc-debian-node image to create a new container which binds to an already existing directory structure. Run the following in the terminal to change to the bind-mounts-and-volumes and start running a new container which we'll connect a psuedo terminal to:
Here we ran a new container instance, bound a local directory (/bind-mounts-and-volumes/bind-directory) which contained a file into it, started an interactive psuedo terminal, printed the contents of the file to STDOUT, then added a new line. Finally we exited the container, and then printed the contents of the newly changed file out. As you can see, the changes made in-container are echoed in the host filing system. Changes at the host level would also have been echoed in the container.
A quick note on the --volume option for bind mounts: Traditionally, bind mounts were specified with the --volume option. This diverged when volumes became first class Docker citizens, which is when --mount was introduced. Whilst you can attach a bind mount to a container using --volume, it is not recommended for those starting Docker, as it reinforces legacy behavior. Try to only use --mount for bind and volume mounts (and just --volume for Docker volumes if really required). Another important note is that a directory or file used for bind mounting must exist prior to the mount occuring.
9.2 Volumes
Volumes, unlike bind mounts, are Docker managed storage areas which can also be mounted into a container. Also unlike bind mounts, a directory path is not passed to the container, but the name of the volume itself. This has several immediately obvious benefit that only the name of the volume is required to work with it instead of a filepath. Another big advantage is that volumes can be of many forms, and not just of local filesystem hierarchies. There are volume drivers for NFS, tmpfs and others for example, which allows them to be far more flexible than bind mounts.
For these exercises, we're just going to use a local filesystem volume.
Volumes, if not pre-existing, are created when a new container that it is bound is created or started. However, we'll go into a little more detail and create one ourselves:
We've created a volume with the name my-volume. Now we can attach it to a new container:
Note that we've again used the --mount parameter to mount the volume into the container, but this time we've change the type to volume. The container ran and a new file was created with some text in the volume.
We'll now run a new container, using a different image, and mount the same volume that we created:
As we can see, the data in the volume has persisted.
Because the volume is just another Docker object, we're actually able to inspect it via the command line with docker volume inspect:
The Mountpoint actually shows that the volume is created in the Docker storage heirarchy, and if we were to inspect the /var/lib/docker/volumes/my-volume/_data directory, we'd find the newfile.txt file.
You can list the current volumes known by Docker with docker volume ls , which we'll try now:
Finally, let's remove the volume to tidy up, we use docker volume rm to do this:
But as you can see, we're first warned that the volume we're using is already in use! This is because we've previously attached it to a container that's only been stopped and not removed.
Because we actually attached the same volume to two different containers, we need to remove both of those containers before we can remove the volume. The removal command actually told us which containers are using the volume, so we can simply remove them first:
10. Container Privileges and Permissions
Containers, as described previously, share the kernel of the host OS (or the underlying Hypervisor or VM). As such, processes run against this kernel. However, this doesn't mean that processes in a container can carry out any operations that they want. To explain this, we need to dig a little into both the user model and the way containers are controlled.
10.1 Users in Containers
Processes in containers run as a child process spawned by the Docker daemon. But this actually raises some questions. The Docker daemon (under Linux) runs as root, and under macOS and Windows runs as a Hypervisor/VM that also essentially has root privileges. So doesn't this mean that all our containers run processes as root?
Well, let's have a look at what we see on a Linux system when we run a Docker container in it (Note: this will not work under Docker for Windows or Docker for macOS, because the processes running will actually occur under the VM and not the host OS). The following command will run the Docker container for 60 seconds (whilst it sleeps) before exiting, and whilst it sleeps we'll have a look at the process running:
The first line carries out a whoami to print the current user of the host OS, the second starts our detached running container and the third searches the host's process list for a command running sleep. This final command finds the running container process (which is run as a child of the Docker daemon), but... it's running as the root user, not as heds!
How can this be? Well, the Docker daemon is actually running (if you've installed it using the default method) under the root user, and because of this any process running in a container is also run by the root user.
Even though the default is to run as root, it's usually better to ensure that the processes in a container run as a suitable user. There's a very easy way to do this, which is to specify the USER directive in a Dockerfile. We'll go into this in a later Masterclass.
However, the question a lot of new users have when they see the process running as rootis usually, 'Is this not incredibly dangerous?'. The short answer is 'No' and we'll explain why in the next section.
10.2 Namespaces, Capabilities, Networking and Control Groups
Let's have a look at a quick example of running a command in a container. Pretty much any Linux distribution allows you (as the root user) to mount a filesystem, and as we've already discovered, processes inside our container are running as root. So let's mount a tmpfs filesystem into /mnt/tmp:
So even though the root user is trying to run the command to mount a tmpfs filesystem inside the container, it's been denied permission. This answers our previous question of why running container processes as root is not inherently dangerous (although still not recommended).
This is due to the way in which containers operate. Whilst all containers share the same Linux kernel that runs on the host OS (or Hypervisor/VM for Docker for Mac or Windows), they run in a separate namespace. This means that any processes that run inside these containers are not allowed to communicate or share resources with any other namespace, including processes run on the the host OS or other containers. Wikipedia has a good article on Linux namespaces that goes into this a little more.
As well as namespace separation, containers also adhere to the Linux capability model, which allows very fine grained control over what container processes are allowed to carry out. For example, should a process need to make changes to a file's UIDs and GIDs, it would require theCAP_CHOWN capability to allow it to make such changes. Without this capability, any attempt to change file ownership in a volume or bind mount would fail, regardless of underlying process user. You can read more about Linux capabilities and the functionality that each capability has access to here. By default, Docker drops almost all capabilities for a container that are not directly required for processes to run in them. Other capabilities are added via a 'whitelist' to open up more functionality.
Containers also run their own network stacks. As we've already seen, just because a container has a process listening on a defined port, it doesn't mean that any traffic will actually make it into the container. There's essentially a firewall between the container and the host's networking interfaces, and the act of publishing ports on a container allows traffic through that firewall (note that this is not true should host networking be used). Users can also create their own Docker networks, and then run containers specifying these networks so that containers can communicate with each other, and the host, where required. These networks essentially contain their own namespacing, so that they can only interact if given permission to do so. The Docker networking overview is a good place to start to read up on networking features.
Docker containers are all subject to the use of control groups (also known as cgroups). Control groups allocate host resources that can be used by a container, and as such can limit the amount of CPU, memory or I/O usage for it. This ensures that a rogue container cannot disrupt a host OS to the point of bringing it down or making it unusable. Control groups for a container are configurable, so a user can alter the resources available to it when required. By default, Docker doesn't limit resources to containers, so in theory you could max out the host OS by running an extremely CPU intensive process in a container, or by using all its memory (though usually the OOM killer will kick in). However, Docker allows you to specify limits when you run a container, and it will then create appropriate cgroup rules on the host to limit the container's resource use. More information on cgroups can be found on the Wikipedia page for cgroups here.
Containers can also use other security features in the Linux kernel, such as SELinux and AppArmor to further ensure that containers are only given access to what they need.
Now that we know that a container has its own networking, namespace and (potentially) limited cgroups rules, we can relax a bit knowing that there's little chance of a container doing anything nasty to the host OS without the knowledge of the user who's running it.
In fact, we've seen this already when creating our first container, where although the HTTP server was listening inside the container, Docker did not allow traffic from the host to the container unless the appropriate ports were published. This is because the container was running its own network stack and had not been given any rules to allow incoming traffic from the host into it.
However, for now, we want to try and still mount a tmpfs mount inside our container, so how do we do it? The answer in this case lies in Linux capabilities. It just so happens that to allow a filesystem mount to work inside a container we need the CAP_SYS_ADMIN capability feature (which also enables a large number of other capabilites for container processes). To enable this, we'll use the --cap-add (for capability add) switch when executing docker run:
This time it worked correctly, because we eased the restriction on the container to allow the CAP_SYS_ADMIN capability. Note that when passing the capability, the CAP_ prefix is dropped.
It's important to note that should your container require elevated permissions or capabilities above that of the default controls, you should find the minimal number of changes required for the functionality required. This way your container will continue to be secured as much as possible from malicious code.
11. Docker Registries and Repositories
Once you've built a working docker image that contains all the functionality you need, it will be stored in the local Docker registry on the machine that you've carried out development on.
We've already seen the local registry, it's the store for images, the list of which can be seen by running the following command:
This local repository stores all of the images that have been built or used when building the images. But how do we now share these images, so that others can use them? Well, think back to our Dockerfile, specifically the first line where we determined which base image to use:
As we know, this tells Docker which image to base the rest of the image we're building on. As you may also remember, on the first build, this downloaded the image. This download came from a remote Docker registry, which Docker itself hosts, called Docker Hub. Any user with an account on Docker Hub can upload images they've built so that other users can download them and run them, or use them as base images. Docker has both public and private registries, depending on the type of account (unpaid accounts only allow the maximum of one private repository, with all others being public, whereas paid accounts allow more private repositories). Docker Hub is the default Docker registry that is used when installing Docker, but other registries can also be used including private ones that you can run yourself. We'll discuss this in a future Masterclass.
We discussed tags in a previous section, where we noted that tags that we give images are of the format repository:tag. A repository name denotes a specific location in a registry for a group of images. On Docker Hub, repositories are usually denoted by the name of a user or organization using the registry and then the repository name itself, these being split by the use of a forward slash (/). For example, the base image we were using was a balena image, in the repository where it stores all of its base images. The base images are owned by the balenalib user, and the repository name is the device type they use as well as the functionality they include, hence balenalib/intel-nuc-debian-node is a base image owned by balenalib which runs on an intel-nuc device based on a debian Linux distribution and includes node (Node.js). Simply, a repository is made up of user/repository-name.
Versions of a particular repository image are then given by a tag, and as we also learnt earlier in the Masterclass, if no tag is given then latest is assumed, which is why the image that was downloaded to the local registry is of tag latest.
We'll quickly ensure that our built Docker image is pushed to Docker Hub so that we can use it anywhere else, or let others use it.
First create a new account on Docker Hub if you don't already have one, using the Sign Up panel (if you already have a Docker Hub) account. If you do have one, sign into it. For the rest of the exercise, we'll assume the user is called dockerhub so remember to replace this name with the actual username (also called a Docker ID) you signed up with.
Next ensure that you login to the default Docker registry (Docker Hub), using:
First of all, there's the matter of naming our Docker image. When we built it, we called it simple-docker-app. This isn't suitable for pushing to Docker Hub however, because that name isn't prefixed by the name of the user who will own the repository on Docker Hub. We'll quickly demonstrate this by using the docker push command, which is used to push repository images to a registry:
As you can see, we don't have access to the toplevel repository because we don't own it.
Instead, we're going to ensure that Docker Hub knows that the image is owned by us by creating a new tag for the repository to include our username. We'll be pushing the latest version of the image we built, so we'll use docker tag to tag that:
Note that when tagging you can use the name of the repository to create a new tag for, or use the image ID.
We now have a repository called dockerhub/simple-docker-app which has a single version tag of latest. We'll try pushing this again:
Success! If you now look at the Docker Hub site in your web browser and go to the My Profile section of your user account, you'll notice that the image has been stored on Docker Hub in the simple-docker-app repository owned by you.
Because we've carried out versioning with the tags, we can also add a new tag to a previous version and then push that:
Note the message Layer already exists. Because the repository we pushed to already has an image (dockerhub/simple-docker-app:latest), Docker noted that our latest push used several of the same layers for its image. Because of this, it didn't need to push them separately to the registry. This is another good example of how the use of layers saves space.
We've created new tags for our images here to push them to Docker Hub, but usually you'll build an image with the user (owner name) directly so that tagging doesn't have to take place before pushing, for example:
If you again look at the profile for your user account and select the dockerhub/simple-docker-app repository, this will take you to a page for that specific repository (you can manage your repository here using 'Manage Repository'). If you select the 'Tags' panel, you'll see that there are now two versions of the image stored in the registry, latest and v0.0.2. This will also show you the compressed size of the images stored on Docker Hub, as well as a copy and paste line that will allow you to pull the image (for example docker pull dockerhub/simple-docker-app:latest).
docker pull is the command used to pull images from a remote Docker registry, allowing any image that has been stored in an accessible registry to be pulled to a local machine's local registry.
So now you know how to store a built image into a remote registry that anyone else with access to that registry can either use to pull and run the image, or use it as a base image for further images (and of course there is no need to docker pull a base image used in a FROM directive instruction in a Dockerfile as it will occur as part of the build).
This Docker Masterclass covered the basics of Docker, and you should now be able to:
  • Install Docker for Linux, Windows or Mac.
  • Use the docker command line interface.
  • Create a Dockerfile and build an image.
  • Run, create, stop and start a container.
  • Understand how to publish ports to enable network traffic in a container.
  • Tag Docker images and write Dockerfiles in a way that allows use of caching when building.
  • Run a container in detached, command mode and interactive mode.
  • Use bind mounts to bind a host directory or file into a container, or create a new Docker volume for storing persistent data.
  • Understand the restrictions on processes running in a container, including the users running the processes and how to enable access to restricted functionality.
  • Be able to store built images on Docker Hub for use by anyone.
Last updated
Was this helpful?
