> For the complete documentation index, see [llms.txt](https://docs.balena.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.balena.io/learn/deploy/release-strategy/update-strategies.md).
# Controlling the update strategy
It is possible to control the order and way in which the steps to perform an update are executed by the balena device supervisor by defining a specific *update strategy*. The strategy allow users to choose between four modes that are suited for different applications, depending on available resources and the possible need to have a container running at all times.
Update strategies can be applied by setting a [docker-compose label](/reference/supervisor/docker-compose.md#labels). The two labels that are involved are:
* `io.balena.update.strategy`, and
* `io.balena.update.handover-timeout`.
Setting the `io.balena.update.strategy` label to a valid value selects the update strategy. The possible values are:
* [`download-then-kill`](#download-then-kill) (default)
* [`kill-then-download`](#kill-then-download)
* [`delete-then-download`](#delete-then-download)
* [`hand-over`](#hand-over)
which are explained below. The `io.balena.update.handover-timeout` label is only used in the `hand-over` strategy, and its use is explained in the [strategy's description](#hand-over).
All update strategies below honor the [device update locks](/learn/deploy/release-strategy/update-locking.md) which you can use prevent updates temporarily.
## download-then-kill
This is the default strategy, and it is selected if the variable is not set or if it has an invalid value. Its behavior corresponds to the way balena traditionally works:
* When an update is available, the Supervisor downloads the new service image.
* Once the download is complete, the Supervisor kills the container for the old service version.
* Immediately afterwards, the Supervisor creates and starts the container for the new service version, and then deletes the old image.
This strategy is suited for the general case of container update, where resources are not particularly constrained (as pulling the new image while the old container runs takes up some extra RAM), and when a zero-downtime update is not necessary but we still want to keep downtime to a minimum.
Is important to notice that the while the strategy is set per service, the supervisor waits until all images for the target release have been downloaded before killing any running services.&#x20;
## kill-then-download
This strategy is meant for resource-constrained scenarios or when the images be pulled are particularly large, so we need to keep RAM usage to the minimum, albeit at the cost of some extra downtime. It works as follows:
* When an update is available, the Supervisor kills the container for the old service version.
* After this, the Supervisor downloads the image for the new service version.
* Once the download is complete, the Supervisor creates and starts the new container, and deletes the old image from disk.
## delete-then-download
This strategy is meant for resource-constrained scenarios or when the images be pulled are particularly large, so we need to keep disk usage to the minimum, albeit at the **cost of extra downtime and higher bandwidth usage.** It works as follows:
* When an update is available, the Supervisor kills the container for the old version, and then deletes the corresponding image.
* After this, the Supervisor downloads the image for the new version.
* Once the download is complete, the Supervisor creates and starts the new container.
This strategy is only recommended for extreme low storage scenarios, where the available storage cannot even fit the target [image deltas](/learn/deploy/delta.md). For most cases, using the default strategy or the `kill-then-download` strategy (if memory usage is a concern), and ensuring [deltas are enabled](/learn/deploy/delta.md) is the recommended approach.
## hand-over
This strategy is suited for scenarios where there are enough resources and it is critical that the downtime is *zero*, that is, that the app runs continually even during an update. For this strategy to work properly, the user has to consider the way the update works and include code to perform a handover between the old and new releases. Its behavior is as follows:
* When an update is available, the Supervisor downloads the new image.
* When the download is complete, the Supervisor creates and starts the new container, *without killing the old one*.
* The old and new releases should communicate between each other so that the old one frees any resources that the new one needs (e.g. device files, database locks, etc) and the new version can start running fully.
* Once this "handover" is performed between the releases (old or new), your service must signal to the Supervisor that the old version is ready to be killed, by creating a file at the path configured under the environment variable  `BALENA_SERVICE_HANDOVER_COMPLETE_PATH`.
* When the Supervisor detects that the file has been created, the Supervisor kills the old container and deletes it from disk.
* If the file is not created after a time defined by the `io.balena.update.handover-timeout` label, the Supervisor kills the old version.
The `io.balena.update.handover-timeout` label defines this timeout in milliseconds, and defaults to 60000 (i.e. 1 minute). The communication between the old and new versions has to be implemented by the user in whatever way they see fit, for example by having the old version listen on a socket or port and having an endpoint for the new version to announce it's ready to take over. It is important to note that both versions will share the folder at `BALENA_SERVICE_HANDOVER_COMPLETE_PATH` and the network namespace, so they can use any of those to communicate. &#x20;
It's also important to note that because the handover requires both the current and target service containers to run at the same time, they cannot configure conflicting resources, for instance, if the old container exposes a port on the host network, the new container will fail to start with a `port is already allocated` error.
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://docs.balena.io/learn/deploy/release-strategy/update-strategies.md?ask=<question>&goal=<endgoal>
`goal` is optional and describes the broader end goal you are ultimately trying to accomplish on behalf of the user. GitBook uses it to tailor the answer towards what is most useful for that goal.
