For the complete documentation index, see llms.txt. This page is also available as Markdown.
Update locks
There are two independent locking mechanisms on balenaOS devices, both using the same lock file path (/tmp/balena/updates.lock):
Mechanism
What it prevents
How it works
Checked by
lockfile
Application updates and config-change reboots. Supervisor will not kill/restart your services
Lock is "held" when the file exists (created with O_EXCL or the lockfile binary)
Supervisor
flock
Host OS update reboots (e.g. safe_reboot, hostapp-update)
Lock is held when a process holds an exclusive flock() on the file
Host OS scripts
During critical operations, both mechanisms can be used together for full protection against app updates, config-change reboots, and host OS update reboots.
For details on the flock mechanism (host OS update reboots), see the OS update locks documentation in meta-balena.
Lockfile (application updates)
Locking updates means that the balena Supervisor will not be able to kill the services running on the device for an update. This is meant to be used at critical sections of your code where you don't want the process to be interrupted, or to ensure that updates are installed only at certain times. Moreover, any configuration changes that will reboot the device won't trigger reboots if locks are applied. Config changes not requiring a reboot will be applied as usual.
In order to do this, users can create a lockfile in a way that it has exclusive access, which will prevent the device Supervisor from killing and restarting the app. As with any other lockfile, the Supervisor itself will create such a file before killing the app, so you should only create it in exclusive mode. This means that the lockfile should only be created if it doesn't already exist. The exclusive access is achieved by opening the lockfile with the O_EXCL and O_CREAT flags, and several tools exist to simplify this process with examples given below.
For multicontainer releases, a release will only be updated if all of the services can be updated. While locks are per-service, having the update lock in a single service will prevent all services from updating to a new release.
The presence of a lockfile will ensure that your services do not get killed, but updates will still be downloaded by the Supervisor, ready to be applied once the lockfile no longer exists.
On devices running Supervisor v13.1.0 or newer, the Supervisor creates lockfiles as the nobody user, with UID 65534.
Location of the lockfile
Note: Trying to remove /tmp/balena or legacy /tmp/resin directories will result in a resource busy error.
On devices running Supervisor v7.22.0 and higher, the lockfile is located at /tmp/balena/updates.lock. This lock is cleared automatically when the device reboots, so the user app must take it every time it starts up.
On older devices (with v4.0.0 <= Supervisor version < v7.22.0), the lock is located at /tmp/resin/resin-updates.lock. The latest Supervisor versions still take the lock at this legacy path for backwards compatibility.
Legacy Supervisors (< v4.0.0) have the lock at /data/resin-updates.lock. This lock is only supported on devices running balenaOS 1.X. This old lock has the problem that the Supervisor has to clear whenever it starts up to avoid deadlocks. If the user app has taken the lock before the Supervisor starts up, the lock will be cleared and the app can operate under the false assumption that updates are locked (see issue #20). We therefore strongly recommend switching to the new lock location as soon as possible.
Creating the lockfile
There are many different tools and libraries to provide proper lockfile functionality and a few common examples are shown below.
Note: Just creating the lockfile, for example by using touch /tmp/balena/updates.lock, is not adequate to prevent updates. A file created in this way won't have the exclusive access flag set, and thus does not provide reliable locking. Additionally, a file needs to be held by a process to be counted by the system as a lockfile.
Shell
One simple way to create a lockfile is using lockfile (available for example in Debian from the procmail package):
For more examples and explanation of the functionality, check the links to the specific tools above.
Javascript
Using the lockfile library, the lock can be acquired like in this example:
Python
In Python you can use the lockfile library
Check the link for more examples and other Python libraries that provide locking.
Overriding the lock
The update lock can be overridden in case you need to force an update, for instance, if your app has hung in a critical section.
The recommended way to do this is to use the 'Override the update lock ...' toggle in the Fleet or Device Configuration page. Go to the configuration page of the device or fleet, locate the 'Override the update lock ...' item from the list, click the activate button, and set the toggle to enabled. After disabling the toggle, update locks may be set again and will be respected.
Also, you can programatically override locks one time by querying the /v1/update endpoint of the Supervisor HTTP API, with { "force": true } as body. Note that this will not set the lock override config var.
Please note that setting the override is a one-time action. Locks set previously are deleted upon setting the config var, and will need to be recreated.
Last updated
Was this helpful?
