# Page Not Found
The URL `getting-started` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Getting Started](https://docs.balena.io/learn/getting-started.md)
- [Getting started with Nvidia Jetson TX2](https://docs.balena.io/learn/getting-started/jetson-tx2.md)
- [Getting started with UP Board](https://docs.balena.io/learn/getting-started/up-board.md)
- [Getting started with Nvidia Jetson Xavier](https://docs.balena.io/learn/getting-started/jetson-xavier.md)
- [Getting started with Nvidia Jetson Nano SD-CARD](https://docs.balena.io/learn/getting-started/jetson-nano.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
GET https://docs.balena.io/learn/getting-started.md?ask=<question>&goal=<user_goal>
### Option 2 — Browse the documentation index
Full index: https://docs.balena.io/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.balena.io/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/learn/getting-started.md`).
You may also use `Accept: text/markdown` header for content negotiation.
